Discuss Fire rated down lights ? in the UK Electrical Forum area at ElectriciansForums.net
Hi there fire rated down lights in a dropped false ceiling with no insulation and 2.5 watt LED lamps in cladding in kitchen with room space above not part of bs7671 but coding opinions if we do for safety ?
If they are fire rated then what is the issue?
They are not fire rated but have low wattage gu10 2.5 watt lamps in them on pvc cladding in a domestic kitchen with a room above would you still fire rate these under no thermal damage visual what so ever
Is this in a standard domestic dwelling, or separate flats?
Do the lights penetrate any fire barriers?
Reply to Fire rated down lights ? in the UK Electrical Forum area at ElectriciansForums.net
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
Hi All, I am currently in the process of building an extension and I need to purchase some led downlights for my kitchen but unsure how many I...
Hi I have a job where customer has two families one families lives upstairs and one family will live downstairs. As the property is going through...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
