Discuss Flickering downlights in the DIY Electrical Advice area at ElectriciansForums.net
Hi :)
I'm currently renovating my outbuilding. My electrician has fitted 10 conduit LEDs (that support both leading and trailing edge) and x4 Meanwell PCD-40-350B LED drivers recommended by my lighting supplier. These drivers apparently support leading and trailing edge Triac dimming.
The problem that I have is that the 3 gang 2 way dimmer switch that I have purchased uses the Varilite V-pro dimmer modules (trailing edge), and the lights flicker constantly when turned on, and both when they are set to minimum or maximum brightness. From my research, it looks as though this is probably because the LED drivers support Triac dimming, but the Varilite V-pro dimmer modules do not.
It looks as though I have 2 choices;
1) swap the dimmer modules out for V-com dimmer modules, which support leading edge
2) swap the LED drivers out for some that will work with my V-pro dimmer modules
Is anyone able to advise which route to go down? If I went with 1), is it ok to use LED downlights with leading edge? From my research, trailing edge seems to be the preferred option for LED lights.
All help appreciated!
Reply to Flickering downlights in the DIY Electrical Advice area at ElectriciansForums.net
I purchased a house that has a really cool 12v halogen setup where two wires are suspended across the ceiling in two different locations, and each...
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
I have two downlights in my hall with MR16 bulbs. These are now leds, obviously in the past they were halogens. The fittings are really old and...
Hi, I currently have 4 JCC LED down lights in my bathroom with a 2 gang dimmer on the outside. The first dimmer switch controls the LEDs and...
Morning All Got little bit situation going on, causing multiple visits (luckily only 2 mins drive from where we are.) Client not 100% happy with...
