Discuss Flickering LED lights in the DIY Electrical Advice area at ElectriciansForums.net
Benny74
Hello all- I hope this is the right place to ask this question. A few weeks ago the LED lights in the kitchen started flickering intermittently, mostly when first turned on in the morning. I changed the light switches in case of dimmer compatibility problem but flickering continued and also happened in other lights on the circuit. This circuit comes from the subpanel. We had the power company check their side and they said there was no problem. We checked the power into the subpanel and it was good. The flickering got worse and spread to other circuits on the subpanel. There was some arcing at the circuit breaker for the subpanel in the main panel (an older Siemen's panel). I changed the subpanel breaker as well as the whole busbar.
This seemed to fix it. The other day there was a buzzing from an outlet in the kitchen for a brief time, and later the power blinked on that circuit. The LED lights (different circuit from the outlets, but all from subpanel) that originally flickered then went down and up in intensity the following morning. Not as bad as the original flickering, but it was there.
My question is, could there be something causing it that eventually led to the arcing in the main panel at the subpanel breaker? The breakers in the subpanel all look fine. I'm not sure what else to check, and I don't want to end up back where I started. Any ideas what could be happening?
Thank you.
Thank you.
Reading what you stated is you heard a bussing sound coming from a receptacle which makes me think that you have a bad connection possibly or something else in that particular receptacle. Your lights and some receptacles are more than likely on the same circuit.
The lights are on a circuit with other lights, which is a different circuit from this receptacle. Both of these circuits and others are on the subpanel.
Reply to Flickering LED lights in the DIY Electrical Advice area at ElectriciansForums.net
I have an old 1959 house that appears to have outside service panel feeding 2 subpanels in the house each with only 3 wire feed. One subpanel(A)...
Hi everyone. I should start by saying I'm not sure I'm in the right place here (this isn't a householder issue - I'm making a Ghostbusters...
I am not an electrician but am looking for some advice as to how to fix my sporadic light flickering problem that has come and gone for the year...
I have an outbuilding a fair distance from the house. In this outbuilding I just want to have some lights, a small music radio/clock, and a...
