Search the forum,
Discuss Fluke 6500-2 Surge Extension test in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hello all,
I am new to PAT testing and have a Fluke 6500-2. I am having an issue whereby I cannot seem to drop the voltage down to 250V when testing a surge protected extension lead. I have read in a couple of places that without a means of lowering it from 500V simply hit the IEC test button, let it do the EB continuity test, let it fail at the IR test, save it and make a note. Is there any way of lowering the voltage so I can run successful tests with these extensions?
Thank you
P.S. Is it me or does anyone else think the Fluke 6500-2 can be a bit unintuitive to use?
TL;DR
How to test surge protected extension at 250V with Fluke 6500-2?
I'm almost 100% sure the 6500-2 is fixed at 500v. As long as all other tests pass then pass the lead and make a note.
Hello all,
Thank you
Hi, I have the 6500-2. May I suggest that you use the auto code 302 for surge protected extention leads- IEC (301) is your standard extention lead @ IR of 500V
Reply to Fluke 6500-2 Surge Extension test in the Electrical Testing & PAT Testing Forum area at ElectriciansForums.net
Hi All, My colleague and I are currently doing PAT/ISITEE Testing, and we've hit a snag with a bit of equipment - we've got 19" Racks for our...
Hi all, The electrical network in my house (Antwerp, BE) is quite old and consists of two phases of about 140 volts. This gives me approximately...
Hi, I carry out PAT testing on landlord appliances for letting agents in rented accommodation. Occasionally some of the items I cannot access...
Hi, I'm a little confused confused is someone can shine some light on the amendment 2 way of doing IR. I know you have to do one 1st fix at 500V...
Hi All New to this forum, have read the posts on here from google but only recently signed up. I'm having some issues and some input would be...
