Discuss fridge not cooling in the Electrical Appliances Forum area at ElectriciansForums.net
You mean compressor? are the fins clean and unblocked at the rear of the fridge, is the cooling compartment iced up?Hi. I have TEFCOLD 1380 that isn't cooling. The condenser is running ok but because I think it's variable speed, it doesn't have a relay I can check? Could it be thermostat? Thanks
Sorry, yes the compressor. I've cleaned everything out and no, icing up?You mean compressor? are the fins clean and unblocked at the rear of the fridge, is the cooling compartment iced up?
You have either lost all the refrigerant charge or the Compressor has gone US time toi get a fridge mech in to have a look and carry out some tests, not something a DIY person can do.Sorry, yes the compressor. I've cleaned everything out and no, icing up?
If air has gotten into the fridge system ,then you deffo have a leak, as the refrigeration system is sealed, a leak would eventually cause a complete loss of refrigerant.One other possibility is an airlock in the cooling circuit, but only if the fridge has been moved and turned on its side. Otherwise, as said above, if the compressor's running and it's not cooling, then it has probably leaked.
Reply to fridge not cooling in the Electrical Appliances Forum area at ElectriciansForums.net
