OP
- Reaction score
- 1
Back to this topic again
here are photos of the area.
difficult to get enough depth for buried cable due to knowing where drains are, when putting in the greenhouse, drain for corner of house just under surface of soil.
Have two main drain access panels at far end of greenhouse(end away from pond end) don't know where these go as in regard as layout to houses.
I was think of running armoured down the wall from loft area behind drainpipe down under small area from house to fenceline then back up on surface behind fenceposts and under the greenhouse base into the greenhouse into weatherproof garage unit feeding pond and greenhouse.
Some peeps say earthrod the garage consumer unit, others say no, no extreneous pipe work entering greenhouse,but is it the done thing to earth the greenhouse frame. Don't want to go the earthrod route as drains are the issue.
As usual advice is greatly recievied, just lack of experience in the phsyical layout of these problems.
Red line indicates armoured route.
Black line indicates suspected drain routes.
Cant seem to get any photos uploaded!!
