Search the forum,
Discuss GFCI circuit protection when replacing old non grounded receptacles in the UK Electrical Forum area at ElectriciansForums.net
Hi All,
I’m a retired electrician from the Detroit area. My question is, I need to replace some old two prong receptacles in my daughters 75 year old home. Code says I can install a GFCI receptacle in the first receptacle of a group of receptacles and install standard three prong receptacles downstream from the GFCI. But, in that scenario I have to locate the first receptacle. That can be difficult in these old homes.
What I would like your opinion on is can I just install a GFCI breaker, for that circuit, in the panel? Then I do not have to worry about which receptacle is first in the circuit?
Tom
This is one for one of our USA members such as @Megawatt
Here in the UK the RCD (GFCI) is normally always in the panel so it also protects the fixed wiring against accidental nailing during DIY, etc.
Hi All,
Tom
Yes that would be fine but they are expensive but there is one stipulation that you have to install stickers on the covers stating no equipment equipment on every receptacle and yes you can install the 3 prong covers.
I have to agree with you that finding the first outlet on a circuit can be challenging in the older houses.
Megawatt, Thank you. I was pretty sure it would be the same as installing a GFCI in the first outlet, but just wanted to make sure. And, yes I still would have had to label the receptacles accordingly. Thanks for you quick reply.
Your quite a my friend
Reply to GFCI circuit protection when replacing old non grounded receptacles in the UK Electrical Forum area at ElectriciansForums.net
A 13-year-old GFCI kitchen receptacle went bad, so I replaced it with a new one I bought from Lowe's (Eaton model TWRSGF20). After one day, this...
Without running new wire or at least ground, next best is GFCI receptacles for limited protection. I know about a bootleg ground to fool a tester...
Hello, I had an electrician install GFCI receptacles (as per their recommendation) due to my homes older electrical wiring. I also have...
I have installed a GFCI breaker the main panel which feeds a circuit that serves two bedrooms. This was done so I could replace all the old non...
Replaced our old 240v hot tub with a new one, which also uses 240v for motors, heater, etc, and 120v for low amp LEDs and touch screen control...
