Search the forum,
Discuss Good quality Alexa compatible switch for boiler in the Central Heating Systems area at ElectriciansForums.net
Having wired in parallel with my cordless programmable room stat an Alexa compatible wifi switch which has failed.
I want to have a app controlled/Alexa compatible switch for switching on my heating system when outside my home or very early in the morning etc, what do people recommend.
I had an ebay switch for £16 which failed.
Separate thing, i'm actually thinking about zoning off the warmer upstairs of my house, any progress in zone valves since I last fitted one 20 years ago?
Thanks,
Garry.
Reply to Good quality Alexa compatible switch for boiler in the Central Heating Systems area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hi all Mate of mine is getting a new utility room fitted, the kitchen fitting company have brought in their electricians for first fix and to be...
I recently wired a heating system with a UFH8 manifold and an unvented cylinder.... easy. Well it threw up a few problems. Initially I had the...
So iv got to add a mini one UFH zone to an existing property's heating system, i have already wired in all the easy parts ie. actuator, zone...
