Discuss Green goo in pvc cable in the UK Electrical Forum area at ElectriciansForums.net
Afternoon all. I’m doing a dorma / loft extension all circuits for that extension are new . I’m going to upgrade the consumer unit also to rcbo/spd. Now I took a switch off yesterday on the existing lighting circuit and noticed the twin and earth cable had a green goo inside the insulation when stripped back it wasn’t a lot I’ve seen worse . Now my question is if all the IR Readings are good is the cabling ok to be left and connected into new consumer unit . I will be doing an eicr on the existing circuits before changing the board so will get a better idea if it’s affected the insulation .
Reply to Green goo in pvc cable in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone, On a job at the moment and trying to Work out cable size needed for property supply. Lots going on and struggle to work out...
Hi, I am changing the electric shower in a bathroom refurbishment (my own) and just wanted to ask about the mcb rating. The existing shower was...
Hey, I lifted a few sockets from a wall so I could paint without having to cut in around them. I haven’t lifted any light switches yet. When...
