Currently reading:
Hager 1361 to rcbo
Discuss Hager 1361 to rcbo in the UK Electrical Forum area at ElectriciansForums.net
N
nc12345
Hi guys
Does anyone know if the old Hager boards with the 1361 fuses will take a RCBO and if so what type ?
I have found Hager RCBOs but not sure if they are compatible.
Thanks to any replies in advance.
Do you mean the type of CU that looks just like a 'new' CU, but instead of CB's inside, it is BS1361 cartridge fuses, in bodies with the same shape as a CB?
If so, then yes, a Hager RCBO will fit in, but it is a tight fit at the top with the other cables there.
Reply to Hager 1361 to rcbo in the UK Electrical Forum area at ElectriciansForums.net
