Discuss Hager Bluetooth AFDD/MCB/RCD Module in the UK Electrical Forum area at ElectriciansForums.net
That ability, coupled with some sort of BT adaptor to wifi/network also in the CU, would be well worth having!You can also monitor current draw , check on fault times etc etc
Hourly rateI fitted a board full if hager afdds earlier this year, i checked firmware with the app at the time and were all up to date, went back for something last week and thought ill have a little check, well theres new firmware available. Each afdd has to be connected one at a time, and to update the firmware it asks you to disconnect the outgoing cables from each one! Fun
Reply to Hager Bluetooth AFDD/MCB/RCD Module in the UK Electrical Forum area at ElectriciansForums.net
