Search the forum,
Discuss Hall stairs and landing light problems in the UK Electrical Forum area at ElectriciansForums.net
we are shortly moving into my parents old house, me and my partner have renovated the property over the last 18 months, we are now nearing completion, but have a problem with lighting on the stairway, there is a light just inside the front door with a double switch, upstairs on the landing is another light with a single switch, im 90% sure that the double switch downstairs has not been removed at anytime during the work, but the upstairs switch has, I replaced the upstairs switch and it turns the upstairs light on and off, but the downstairs double switch will only operate the downstairs light on and off, pic 1 is the wiring on the double downstairs, pic 2 is the upstairs switch wiring and pic 3 is the upstairs ceiling rose, any help to whats wrong would be very welcome, thanks in advance
That’s a two pole switch and isn’t suitable for two way switching. As Murdoch has said, get a local spark in to sort it out, won’t take long and shouldn’t cost a lot.
caustic comments aside, OP. you have fitted the wrong switch. please call in a local electrician to do it right, should not cost more than £60.
This is a very basic error, so please be careful with what you attempt in the electrical line and get advice wherever things do not seem right.
The switch should be a 1 gang two way light switch
and should probably be wired as two wire wiring. However be aware that the upstairs light will be connected to the downstairs lighting, possibly crossed over.
While the sparks is sorting out the light switch, I'd show him/her that ceiling rose, seems to be some bare copper wire there?
Perhaps all your wiring needs a bit of inspection.
Reply to Hall stairs and landing light problems in the UK Electrical Forum area at ElectriciansForums.net
Suggestions / solutions please anyone? I have a 2 way switch, Hall and Landing, power being fed on Landing. When the switch is turned on, the...
Hi folks, Quick query for this still practicing regarding bill payment for a job not complete. My partner recently employed an electrician to do...
Hi I want to add a light to my attic. There is a single switch on the landing that I want to change to a double switch and then use it to still...
