Discuss Heat trace caught on fire in the UK Electrical Forum area at ElectriciansForums.net
Hello,
I am in the process of conducting an investigation on a heat trace that was found on fire.
The jacket around the wires could have been damaged from the installation of a regulator that was replaced prior, but I can not 100% confirm the damage since it burned in the process. The insulation had been removed for the installation of the regulator and never replaced. So the heat trace that caught on fire was exposed to the elements.
(The plant has a winterization program and PM inspection on heat trace).
1. Can I get some ideas on why the heat trace caught on fire?
2. What recommendations would be proper to prevent this from happening again?
Thank you!
Caro
Hello,
Thank you!
Caro
It had to be damaged prior to installing the insulation. What I always did when we installed the power was to fully inspect it where the valves and transmitters were installed to isolate any potential problems.
Reply to Heat trace caught on fire in the UK Electrical Forum area at ElectriciansForums.net
Hi everyone Ive just had an electrical condition report conducted on a mixed-use property, and I am extremely surprised that after the last report...
Hi, Have normal fused immersion heater switch. I would like to add a smart wifi switch to it so when my Solar is producing over 3k spare, going...
I'm having a bit of a disaster at the minute and would like an honest opinion. I am having a gas stove fitted in the corner of my room and...
Hi everyone We have a little problem with a heating system on one of the projects (quite big house in south Kensington) and we are looking for...
We have this Swiss-made Dixi horizontal borer from 1957, very nice machine still with its original DC variable voltage drive. In those days there...
