Discuss Help needed with led light strip in the DIY Electrical Advice area at ElectriciansForums.net
Hi there,
Please can I have some help with the following:
I want to have some perimeter lighting in the ceiling which will be using the aluminium profiles that are plastered in.
I am going to be using the following:
FCOB RGBCCT LED Light Strip 6 Pin 12mm DC24V 960 LEDs RGB CW WW FOB Flexible COB Linear Lights High Density RA90 Dimmable 18W
I am going to use 3 of these strips in parallel to make 14m.
I want to use the following controller:
LIGHTEU®, Milight Miboxer 5in1 WiFi LED Strip Controller, Amazon Alexa and Google Home Voice Control Remote and APP Control, no WiFi-Box Needed Compatible with 5 Different Output Mode, DC12-24V, WL5 https://amzn.eu/d/hZnajYC
Can I group all the 6 core wires to the individual ports in the controller and the power through one transformer?
Also would anyone be able to help me calculate what power supply I would need?
Thank you in advance.
Reply to Help needed with led light strip in the DIY Electrical Advice area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
Hi All, I am currently in the process of building an extension and I need to purchase some led downlights for my kitchen but unsure how many I...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Wanting to add 2 strips of led lights down each side of underneath of the stairs, I have a socket I can spur off, into a fused switch, been...
Hello, I'm new to this and I'm looking for someone to review my wiring diagram. I'm not sure if I need a fuse block because I'm using an XTM...
