Search the forum,
Discuss Help testing small motor in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
Friend of mines dryer machine has stopped working, 2 days out of warranty.
I am trying to help theme out as money is tight for them however, I'm a little unsure my diagnosis is correct and I don't want them spending unnecessarily on replacement parts.
The dryer is a Candy machine and has a small induction motor with a 5uF capacitor. When you try and start a programme the dryer clicks and then a humming noise which stops after around 30 seconds, there's also a burning smell. If you keep doing this the motor gets quite warm.
So, I suspected the capacitor, i tested it and its measuring exactly 5uF. I did this with my fluke meter and the connections removed from the capacitor, I also made sure it was discharged.
I removed the motor from the machine. The motor shaft spins freely and i could not see any signs of damage or discolour. I started a programme again and the motor shaft started to spin very slowly and then stopped, again with a humming noise and then a burning smell. I have tried assisting the motor by turned the shaft by hand, but with no luck.
I cannot find a wiring diagram for this motor but I assume it is a induction motor with run and start windings. The reason I suspect this is because, there are 3 cables feeding the motor from the control board, 2 of these conductors are connected to the capacitor.
When the programme starts there is 230v to earth on all the cables that feed the motor and the capacitor.
I have concluded that the motor is at fault but I am not 100% sure I have followed all the tests possible to conclude this for sure.
Any help would be appreciated.
I would agree that the motor is by far the best part to replace.
if it is powered and not turning then it is broken. Keep it simple!
Reply to Help testing small motor in the UK Electrical Forum area at ElectriciansForums.net
Hi all Back in July last year I installed a new pool pump/motor. The problem is it's now making a humming noise and trips the breaker. I...
Hi, First of all I must explain why my posting came to be on this site, I was looking on the internet for a forum that could help with a project...
Hi, I have a project I have been working on, that has me out of my depth with regard to my knowledge, as I am a very basic electronic hobbies...
hello!! hope anybody can help me. I have an AC single phase 220v 1.5HP motor that won't rotate when plugged in even when I try to do it by hand...
