Search the forum,
Discuss Hive receiver connections to Vaillant boiler in the Central Heating Systems area at ElectriciansForums.net
I have a Vaillant EcoTec Pro 28 boiler and a Vaillant mechanical thermostat (unsure of the precise model) and I’m thinking about installing hive to be able to access the remote switching feature and also to able to place the thermostat where I want it rather than where the installer thought it should go.
I should say upfront that I’m not an electrician and having looked at the board inside the boiler I’m leaning towards buying hive with the installation option, I expect that’s what the advice would be anyway to avoid any issues but my curiosity has the better of me and I wonder if anyone could offer any insight into how the hive receiver should be wired into my particular boiler. I have taken a picture of the board inside the boiler and also have the wiring diagram but I can’t identify where the various wires should be connected, anyone who knows care to offer their expertise, just to sate my curiosity? I noticed when looking at the board that there seems to be a second board beneath the one that’s visible in the picture, would it be necessary to access that to make the connections? Really appreciate any help.
yeah wright, time to get one in .
Thanks for the reply but in the context of my original post I'm no wiser. I was seeking specific advice as to which connections on the receiver go to which specific connections in the boiler.
You are the latest in a very long line of posters expecting unpaid professionals to provide you free advice.
So you could call hive, or call the boiler company or employ a local person ...... I suspect the first 2 options won't answer and tell you to speak to the other ...
Your choice
The RT, purple terminal is the return from your existing roomstat. Roomstat needs disconnecting. This is where the return from your hive receiver will connect to. The rest should be obvious.
Your choice
Feeling better now? Are you perhaps one of those unpaid professionals you refer to? Maybe you could have provided the information I seek in the same number of keystrokes it took you to type the above but it's much better to make yourself feel superior, isn't it? As I said, I am intending to have professional installation but was just interested in what goes where, but never mind, clearly no help to be had here. There was me thinking that internet forums were places where one could seek help, silly me. Oh, and by the way, if you feel inclined to respond I just thought you might like to know that I wont see it, I'm done with this forum, frustrating isn't it?
It’s easy to do, all you have to do is take out some of the wires and put some wires in then sit down have a beer and turn you heating up and down on your phone, here’s the diagram for all you need to know
Sorry will not post
Frustrating isn’t
@diditrain gave you the answers in posts #9 and #10.
If getting a professional in I don't know why you need to know what goes where
im about to install a hive to my boiler ecotec
remove the link between rt
hive reciver L N E for power same supply as boiler spur
RT to 3 on hive reciver (rt feed next to L N E
Live to 1 on reciver
from what i see there will be 3 L going into the boiler with reciver wired
please confim im correct b4 i get my screw driver out
cover of the front boiler what a load of tat.
A lot of modern boilers draw the outside air for combustion in to the boiler body before it enters the combustion chamber. The body of the boiler is sealed at all pipe and cable entry points and the front cover has a continuous seal around it so that room air can't be drawn in.
We had a new boiler about 6 months ago and I asked the plumber about it- he said that you are supposed to be Gas Safe registered (or no doubt considered competent in some other way) to remove the front cover on this type of boiler. He said that as long as you fit the cover back on correctly, there shouldn't be a problem but he couldn't advise you to do this yourself...
Having said that, a different Gas Safe plumber put the cover back on our old boiler a few years ago and didn't seat the seal properly leaving a big old gap, so either way, you take your chances...
Funny how your original message ends with you saying that you appreciate any help and when someone gives you good advice and is a great help you then spit your dummy out. You could end up killing innocent people if you mess around with gas and electricity especially mixed together. Don't be stupid and pay someone to do the job safely it won't cost more than £100.
Hey, did this end up being the correct setup? About to jump into my Ecofit Pure and try similar?
Reply to Hive receiver connections to Vaillant boiler in the Central Heating Systems area at ElectriciansForums.net
Hey everyone, hope you all had a good xmas. Got called around to change over an old style pin type thermostat to a hive one for a family member...
Hello, I'm in the process of changing my wired remeha thermostat with the wireless hive mini, I've had a look at the manual and believe I have...
Hi folks, I'd like to get my Nest thermostat up and running with the gas combi boiler (Worcester Greenstar HIghflow 440 Standalone). FYI - I...
Good afternoon chaps, I have an Alpha E-Tec 33 combi boiler (with Google Nest 3rd Gen thermostat) that occasionally fails to put out hot water...
I am installing some driveway lights. The customer wants to be able to switch them on from t he house, but also have a PIR at the driveway...
