Search the forum,
Discuss Honeywell Remote Servicing Suite in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
freddo
Supporter
Hi All. I have Honeywell Remote Servicing Suite V6, I can connect to the Galaxy Dimension 48 and panel I want to work with, but I can't do anything more as the panel has software V7.03 and the RSS software only supports up to V6.99 :( Is there an update for the software to allow it to work with the V7 panels?
I've sorted it. I finally found the software update patch on the Honeywell website. Most of Honeywells links just gave 404 errors the first time I looked, took ages to find a working one!
[automerge]1585683777[/automerge]
I suppose it would be useful to post a link! At the time of posting the patch and update notes are available HERE. The EXE. file is simply run on the computer the software is installed on.
Reply to Honeywell Remote Servicing Suite in the Security Alarms, Door Entry and CCTV (Public) area at ElectriciansForums.net
Daughter has bought a house and it has a home security system, G-Tag setup. Issue is the alarm panel displays are pixelated and you cant see...
Hi everyone, first post here and in a bit of a pickle... Newly qualified out in the big bad world... I have a job 4 hours from the office so I...
hi guys / girls , any advice would be appreciated, So the situation is a domestic property has a 3 phase supply , from the service head we have 3...
Heeelp! I have an 11kW/21A motor which is attached to a hydraulic power pack. I have replaced the old panels with new, using the same star delta...
I currently have solar array and was going to purchase Shelly EM to monitor Grid in/out and solar production. So far so good. But I also plan in...
