- Reaction score
- 0
Intermittent fault with a Hotpoint oven .Sometimes comes up to temperature,more often now,it doesn't.Other functions work fine,grill etc.Any thoughts?
Discuss Hotpoint oven fault in the Electrical Appliances Forum area at ElectriciansForums.net
Thermostat ?Intermittent fault with a Hotpoint oven .Sometimes comes up to temperature,more often now,it doesn't.Other functions work fine,grill etc.Any thoughts?
Probably worth replacing the thermostat anyway if you are going to the trouble of taking the panels off to investigate if there are any loose connections etc.Sometimes comes up to temperature,more often now,it doesn't.
Reply to Hotpoint oven fault in the Electrical Appliances Forum area at ElectriciansForums.net
