Search the forum,
Discuss How can i have power flowing in a circuit where 1 item works but rest of chain does not? in the Electricians' Talk | All Countries area at ElectriciansForums.net
cory123
There is power flowing. I have checked with multimeter. One light on the line works..even replaced the switch it is connected to. Rest of line still down. Been down for months since a large storm although no indications of lightening strike. Replaced breaker on Sunday...no dice. On Tuesday power came back. This morning (wed) my son overloaded and tripped a completely seperate breaker that then caused the other line that had just mysteriously come back to go out once again. I replaced the breaker that had tripped as well. Still no go. I have checked the neutrals in the panel...in fact I moved the one from the bad circuit to an new open spot just to see. I am very confused. Nothing seems to be making sense. When I was replacing the breaker that tripped today on the opposite side of the box I did notice scoring or burns on the bus under the breaker above it although that breaker works fine. Might not be connected but wanted to give as much info as I could. Any thoughts from an electrician?
It sounds like you have a poor connection through the lighting circuit.
As for burn marks under the breaker are these Stab-Lok style breakers.
Stab-lok are the ones that hook on the bar and pop onto the bus plate correct? That's what mine are. I did recheck the connections behind the light fixture that does work and nothing is off. I know my basics which is why I am even more confused.
Reply to How can i have power flowing in a circuit where 1 item works but rest of chain does not? in the Electricians' Talk | All Countries area at ElectriciansForums.net
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
I installed outdoor lighting and outlets. I finished this past year. I passed my inspection on April 2022. I was so pleased, BUT now the circuit...
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
