Discuss How can i start a different pump at each start ? in the Commercial Electrical Advice area at ElectriciansForums.net
So I have 2 pumps, when i turn a selector on i want to start the first pump.
Once the selector was turned off and on again, I want to start the second pump.
And any time i repeat it i have to turn on the other pump which was not running on the previous startup.
How can i do this whitout a PLC ?
Smart relays are easy enough with drag and drop logic/function blocks and cheap. Basically a mechanical mini PLC.
What’s wrong with 2 interlocked switches?
Thank you for your response.
Could you give me an exemple for a smart relay which can do that?
Because basically I also thought that, but I could not find relays like that 🥺
Reply to How can i start a different pump at each start ? in the Commercial Electrical Advice area at ElectriciansForums.net
I've always thought I was quite good a wiring heating systems, I can do Y plan, S plan, UFH set ups, "normal" thermal stores etc, you name it and...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Hi, Small flat, currently has a small'ish feed water tank, top of a cupboard, feed through a wall into under stairs cupboard. Hot water tank...
Good evening, I have recently moved into a new home and I am having problems with the MCB/RCD tripping (Mem M6 Type 3 - 30mA). It intermittently...
Hello! I'm needing some help. I'm wiring in a start panel, using a spst toggle, and a (momentary?) push button. The idea is to flip the switch to...
