- Reaction score
- 3,928
Just a quickie to show you how to add a directory listing to the forum.
N.B. If you want to skip all this and get Dan to do your listing for you, and optimise it, and it then gets featured at the top of all listings, click here: Get Your Directory Listing Optimised by Dan via Forum Subscription Service (Examples Inside) - https://www.electriciansforums.net/threads/get-your-directory-listing-optimised-by-dan-via-forum-subscription-service-examples-inside.178897/
Step 1: Click Electricians Directory in the main menu - Link is also here: Electricians Directory
Then you will end up on the following screen.
Step 2: Find the category from the main menu in which your company is mainly based. So it's just one county for now. We will enable the adding to two or more categories once we have populated the directory a bit. So pick the one your head office is based, or the county you get most of your work from etc. For the example, I've selected the Electricians in Berkshire category, which was in Electricians in England menu. This currently has no actual listings so it's a fresh category.
Step 3: Click the orange "Add Resource" button.
Step 4: Fill in all the details and click save.
Simple as that. Your listing should have a couple of images in it, some bullet points about what you provide service-wise, that kinda jazz. Then your contact details.
IMPORTANT: Listings with very little information in them WILL NOT GET YOU CALLS / WEBSITE TRAFFIC!
If you would like to skip all this and get me to add your listing for you, and optimise it so it has the best chance possible of ranking well in search engines and the forum search etc, then please see the following information regarding forum subscriptions. It's basically £45 for a spot-on optimised listing, that is featured above all others (once it's populated that'll be important). Get Your Directory Listing Optimised by Dan via Forum Subscription Service (Examples Inside) - https://www.electriciansforums.net/threads/get-your-directory-listing-optimised-by-dan-via-forum-subscription-service-examples-inside.178897/
