Currently reading:
How to "Monitor" a RCBO??
Discuss How to "Monitor" a RCBO?? in the Lighting Forum area at ElectriciansForums.net
LukeD
Supporter
Anyone think of a way for a 'tripped"RCBO to notify property owner etc. Client has a valuable display cabinet thats fed from a RCBO (Radial) . But wants to know if it ever "trips" ? And the cabinet loses power .
Feed a relay from the same circuit. Use the normally open contacts to feed either an alarm, a lamp, or even to trigger an autodialler or similar.
In fact a good solution would be to get it to trigger something that Google home recognises, and then set a routine in the Home app to do whatever you want. This way it's very customisable.
If you are REALLY paranoid you have it cut off a regular status contact so the loss of power or connectivity is noticed...
Reply to How to "Monitor" a RCBO?? in the Lighting Forum area at ElectriciansForums.net
