Search the forum,
Discuss HSS Drill Bit Set Recommendations in the Electrical Tools and Products area at ElectriciansForums.net
Pop into a local engineering supplier - they tend to keep decent quality HSS bits at sensible prices.
I top up my stock of bits as necessary and never bother with nice sets as only having one of certain sizes would be of little use. If you do want a set, the only advice I can give is to avoid buying cheap as you'll quickly find they cut about as well as crayons.
My dad 20 years ago bought me a big set of eversharp hss metal bits and they are still going
as above , avoid cheap ones as they won’t cut metal and really only good for plastic
Heller or Irwin are good. avoid all the "titanuim coated" crap on ebay. they're more likely made of cheese.
I will have a look at those. I’ve seen these:
View: https://www.amazon.co.uk/dp/B076F43HPH/?coliid=I1FN3KVJK3K1FP&colid=3KZ6WHVK8PP1Q&psc=1&ref_=lv_vv_lig_dp_it
But on the Heller what I am best going for as there is Tin, Co Cobalt and others as I’m starting out so for now I’m looking at a set. I can then as I get more experience look at individual drill bits as and when required.
that bosch set is a good starter. then as you wear any out, just buy singles, unless you are adept at sharpennig.
It also depends on how much you are willing to pay. Something like this is good but not cheap:
Typically though you will find you break the smallest sizes (e.g. 2mm or so as pilot drill for smaller wood screws, etc) and blunt the more useful larger sizes, so worth looking at some spares. Also if you do more "engineering work" you might need the odd sizes that are drilled before tapping a hole.
Reply to HSS Drill Bit Set Recommendations in the Electrical Tools and Products area at ElectriciansForums.net
Has anyone tried Erbauer Holesaws and Drill Bits? I’m just after an assortment of bits as our company pay for your drill bits. They won’t pay for...
I’m new-ish to the trade and going to be working on site in a new build block of flats as an Adult trainee/apprentice, I’ve been told to bring my...
5K
Hi all, Firstly I am new to the forum, so will start by saying hi. I work as an electricians mate, and am joining the forum to gain experience...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
Good evening all. I have a couple of learners with hypermobility issues - which causes their hands to be sore after a day in the workshop. Has...
