Search the forum,
Discuss I always wondered what the little holes are for! in the UK Electrical Forum area at ElectriciansForums.net
Found this on my travels today visiting my favourite customers. I hadn't noticed this previously and I can only assume this is the result of a recent 'solar PV service' the customer had last month.
My customer asked for my opinion as she had also not noticed the wire previously, the words 'I dunno, but summat smells fishy' were in my head and on the tip of my tongue but the what came out was "F*ck, that looks ropey as!".
I assume this isn't standard practice to wedge a wire in with a fancy twist to get the 3 phase solar PV to trip. Should the correct item should be a 3 Phase 16A MCB rather than 3 tied together?
Your link takes me straight to mcb's.
But they are definately RCBO,s next to the 3 phase thing/ 3 mcb's
Nice attempt to dodge the bullet of being wrong! Why point out what the other PDs are when the op is referring to the MCBs? I’m very confused
Thanks for replies chaps.
If you hadn't of guessed already, I know naff all about PV. Could anyone explain what this workaround is trying to achieve?
What would happen if the link isn't in and a single phase drops off? Would the invertor be damaged or just a lack of balanced power back to the grid/less generated power being fed back/less income?
I stand corrected they are RCBO's next to the 3 x S.P. MCB's and the RCBO toggle is smaller than the MCBs hope that clarifies that. The 3 x MCB's have a makeshift link that has not been type tested to operate in simulation.
Not dodging anything, as you say your a little confused.
Anthony brag was compairing them with the other single pole devices in post 5.
But Phil Thompson correctly pointed out they where RCBO,s in post 6. I agreed with Phil Thompson.
Reply to I always wondered what the little holes are for! in the UK Electrical Forum area at ElectriciansForums.net
