Currently reading:
Installing Coax, Sky Cables and TV Booster
Discuss Installing Coax, Sky Cables and TV Booster in the UK Electrical Forum area at ElectriciansForums.net
atm-12
Hi, I was hoping somebody could point me in the right direction to learning a bit more about installing Coax and Sky cables and the arrangement from the sky dish, antenna, booster and TV points. I have installed this plenty of times but have always been told what cable goes where and then a TV specialist will connect everything in the second fix. I just want to get my head around it a bit more, maybe a good website or any books and diagrams. I have tried searching google but not exactly sure what to search for.
loads of info on here SatCure UK satellite and Freeview information - http://www.satcure.co.uk/
Technical index is on the left in orange if you scroll down.
here's an example of a multi switch setup.
Installing a multiswitch for multiple satellite points - http://www.satcure.co.uk/tech/multiswitches.htm
Reply to Installing Coax, Sky Cables and TV Booster in the UK Electrical Forum area at ElectriciansForums.net
