Discuss Installing groundwire system in the DIY Electrical Advice area at ElectriciansForums.net
My 1951 CA home (none of original wiring grounded) has 7 receptacles* that have a separate ground wire extended into the subfloor and connected to the galvanized water pipes. Those pipes will soon be replaced with PEX. My plan is to drive ground rods with a new ground wire extending from the rods into the subfloor where it will connect to the wires from each receptacle. All of the ground rod installation information I see shows 2 rods separated 8-16 feet. To make it one continuous wire, the total run will be about 150 feet.
1) I presume a single, solid, bare wire is best. What gauge should I use? (I have seen Youtube recommendations for 4, 6 & 8 awg. The circuits originate at a 100 amp fuse box.)
2) Does the wire need to be solid or can it be stranded?
2) Does the wire need to be Continuous or can I branch using connectors (which would shorten the run considerably)?
3) If the wired needs to be solid and continuous, the only suitable connectors I have see are the split-bolt, but those suckers are expensive. Is there something else that will work?
4) By extending the run about 10 feet, I can have ground rods at each end of the wire; they will be about 30 feet apart ("U" shaped house). Is there any problem with that?
Thanks.
* Some receptacles are GFCI; I plan on making them all GFCI.
Reply to Installing groundwire system in the DIY Electrical Advice area at ElectriciansForums.net
Short version: does code specify a minimum distance from the panel to the first grounding rod, and if so, what is that distance? Long version...
Without running new wire or at least ground, next best is GFCI receptacles for limited protection. I know about a bootleg ground to fool a tester...
Recently moved into a house from the 70s. There's no ceiling light in the living room. Assuming the switch for the room was to one of the outlets...
I have an outbuilding a fair distance from the house. In this outbuilding I just want to have some lights, a small music radio/clock, and a...
Hello, I had an electrician install GFCI receptacles (as per their recommendation) due to my homes older electrical wiring. I also have...
