Search the forum,
Discuss Installing plug sockets in steel furniture. in the UK Electrical Forum area at ElectriciansForums.net
Hi all,
Figured I'd come straight to the experts with this one because I don't have a great deal of electrical experience.
I'm a designer at a furniture manufacturing company. We manufacture furniture almost entirely out of folded sheet steel profiles.
Currently I am working on designing a bespoke kitchen for a client, this client would like UK mains sockets installed on a couple of her units.
I'd just like to know if there are any regulations or best practice rules when it comes to installing electrical systems on a metal surface.
As far as I understand I'd need to ensure that the steel units are earth bounded to the structure of the building, is there anything else that I need to be aware of?
I want to make it as painless a job as possible for the electrician doing the install. Any advise would be much appreciated. Thanks in advance!
L
All the metal units will indeed require Bonding. Not sure what others thoughts are but personally I in your installation documentation I feel you must insist any customers already have RCD type protection fitted supplying the power to any sockets fixed or fitted to your units.
Couldn't the metal cabinets become live under a fault condition and if not bonded give some one a Zap? Especially if sockets are installed in them?
I don’t think they are metal cabinets, from my understanding it’s the metal back boxes he’s talking about.
Will you be supplying the metal furniture item with the sockets already installed and wired, with just a cable or terminal block for the installer to connect to the house's electrical system?
The two issues I can see are:
  1. The metal of the structure has to be connected to the CPC (earth wire) of the supply to the sockets. That might just happen due to the mechanics of attaching the sockets via their fixing screws but that is not good enough - you must ensure there are proper electrical connection point(s) to guarantee it. Typically this means a hole with unpainted metal so a screw and terminal will make a good connection there, or a welded stud that (again) has protection to make sure its thread is not covered in any paint. Ideally that would be pre-wired to any junction box along with the cabling and factory tested.
  2. There are two choices of wiring for UK 13A sockets, one is the radial where a single cable from the CU (consumer unit = fuse box) feeds all of them, the other is the "ring final circuit" where the cable loops round and eventually goes back to the CU again. To avoid yet another religious war I won't discuss further, but ideally if you have the unit pre-wired it should be suitable for either radial or RFC use, and than means both ends are available at any junction box where house wiring enters the furniture. That way the installer can do either.
exposed conductive part:
Conductive part of equipment which can be touched and which is not normally live, but which can become live under fault conditions.
If it has cables running through it, could it not be considered by the devils advocate to be an exposed conductive part?
i don't know where this furniture could be fitted, but if it were in my house, i think i would prefer it to be bonded in some way.
Reply to Installing plug sockets in steel furniture. in the UK Electrical Forum area at ElectriciansForums.net
Hello all, Looking for help here as I've come across a strange call-out today. Bare with me here: Got a call from a customer saying they had...
Hi, plumber here so please be gentle (or take the p-ss ;) ), I am supposed to be installing a UV water steriliser for a customer. I have some...
Hi All, We have an old Country villa in Spain. The housing electrics were not good so the house recently has been completely re-wired to a good...
Hello fellow professionals, I'm currently facing a challenging scenario that involves the integration of solar photovoltaic (PV) systems on roofs...
