Search the forum,
Discuss intermittent booster box fault in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
A
Anne
I wonder if anyone has any ideas - my TV is driving me crackers!
Our TV is connected via a a DVD player / recorder to a signal booster box (which sits next to the TV) and then to a rooftop aerial, we watch freeview. For many months this has worked just fine.
A few weeks ago, I would sometimes turn the TV on and have a 'no signal' message on the screen. If I wiggled the cables on the booster box then the picture would come back. Then I realised that if I turn the booster box off and on again, the picture would come back. At all times, DVDs were playing fine and I could view them on the TV.
I decided this was not a good solution so I bought a different booster box. I couldn't get any signal at all - even when I re-tuned the TV. I tried another different booster box - again no signal. So I then bought new cables and a new booster box identical to the first one. I still have the same problem! When I turn the TV on (witht the new booster box and new cables), no signal. When I then turn the new booster box off and on again, the picture is fine. Sometimes, the signal goes during a programme so I spend quite a lot of time jumping up to turn the booster box off and on again.
I have tried connecting the TV directly to the aeriel socket, but there is no signal ever.
I have no idea what this fault can be! I'd be really grateful for any ideas. Many thanks!
Definitely sounds like an issue with your aerial.
as murdoch has suggested, a TV 'chappie' is ideally who you need.they will measure the signal and quality and advise of the best solution.
keep us informed as to what happens ☺
It does sound as if there is a loose connection or something at the aerial end.
The aerial may have dropped on its mounting or twisted so it is no longer in signal range, the connection to the aerial cable may have become corroded or loose.
If you have a connection box in the wall that connects to the aerial then the problem could be there as well.
Ah mharries it appears you are the closest! I had a TV repair person out today. Here is my best, lay-person description: on our roof near our aeriel is a signal booster. It used to have its power supply sitting by our TV (I didn't know this! I thought it was the booster by our TV!). So, when the power supply thing failed, I bought a signal booster box and plugged it in by our TV. Somehow by an odd twist of science, my signal booster box by the TV mostly managed to power the orinigal signal booster by the aeriel. However, it needs a 'jump start', hence having to turn it off and turn it on again.
Very helpful TV repair person replaced the booster box I had bought with a power supply for the rooftop booster box. And now it all works fine (as far as I know, at least it did while he was here!)...
And now I know more about how it all works, which is always helpful.
Reply to intermittent booster box fault in the Freeview and Terrestrial TV Forum area at ElectriciansForums.net
Hi everyone, I am new to the forum and wanting some advice regarding a tv aerial. I moved into my own flat and bought a tv, however when I...
Hi, I'm splitiing a signal from my main TV Aerial using an 8 way booster which is located in the loft The Tv's on the longest cable run from the...
Firstly, I hope it is ok to discuss the wiring of speakers here. TBH my ignorance in all things electrical knows no bounds, and I am guessing it...
1pm, quite happy doing my planned job. Builder then asks if I could go out to another job where the top lights have all tripped out. I like peace...
Hi Guys and Girls, First off: I am very new to electrical stuff. Right now I'm running my first ever project containing electrical components. So...
