Discuss Is 4mm heat resistant cable okay for 7.5kw range cooker? in the UK Electrical Forum area at ElectriciansForums.net
chris140
The electrician that installed my cooker circuit put in 10mm cable with a 32a fuse, a 45a cooker switch and 10mm cable to the backplate for behind the cooker. He put this size in as I didn't know what size cooker I was going to be getting.
I ended up getting a 7.4kw range cooker and the electrician has connected it with 4mm heat resistant cable instead from the cooker to the back plate, instead of 6mm. Is this okay, and is it okay with the 10mm cable and 32a fuse?
At least he used heat-resistant cable, most just use twin and earth.
i see i misread.... its 7400, not 7200
32.17A.... but still..... never going to pull that much
quite right, allowing for diversity I doubt it will pull 20 amps.
Reply to Is 4mm heat resistant cable okay for 7.5kw range cooker? in the UK Electrical Forum area at ElectriciansForums.net
I have just had my kitchen redone and the kitchen rewired with a new 6mm cable installed for an electric cooker. However I have changed my mind...
Hi folks, DIYer here, hoping for some advice before most likely calling in a spark. I'm looking to wire in new cooker and hob (separate units)...
Hi, during kitchen refurbishment, the electrician installed a 4mm cable and 32a breaker for the new induction hob rangemaster oven that is rated...
8K
