Discuss Is pvc pvc T&E soon to be written off ? in the UK Electrical Forum area at ElectriciansForums.net
Dustydazzler
Supporter
I made a very rare trip to my local wholesalers today (I usually buy stuff online now and have it delivered) and was speaking to the manager who I have known since college.
He reckons in the coming amendment to the regs , grey pvc pvc twin and earth cable will be written off and we will be required to use LSF / LSOH cable domestically...
anyone else heard this ?
Sounds like salesman speak for either
1 I have loads of lsf cable that I must sell
2 wow, the mark up on lsf is 10% more than pvc
He was absolutely adamant that this was a genuine amendment that LSF will replace pvc pvc ...
can see loads of future eicr reporting that full rewire required due to old pvc wiring
Don't recall anything in the proposed AMD 2 - though there might be a push from someone like the Fire Brigade after Grenfell perhaps?
I suspect most of what the wholesalers come up with is what they are told by the manufacturers, so more than likely a cable manufacturer looking to drum up business on a higher profit line...
Maybe the cable cartel is miffed that most PVC wiring from the 70s on is still more or less fine and doesn't need replacing yet
New posts
Reply to Is pvc pvc T&E soon to be written off ? in the UK Electrical Forum area at ElectriciansForums.net
Recently a couple of threads have discussed T&E cable and it became apparent to me that the 2.5mm, which I have only ever seen as solid core, is...
6K
Evening all. I've been working on an early 70's house the last 2 days - 1st fix for a lighting alteration, plus minor remedial work on the ring...
Hello, Whilst doing some building works I have access to the inside of the stud wall to which the consumer unit is fitted, so full and easy...
4K
  • Locked
Hi, we need some advice on our scenario with regards to our rewire plan. I will get this out of the way first... We are planning to put the house...
5K
