Discuss JCC Toughbay - Emergency Issue in the Lighting Forum area at ElectriciansForums.net
Had an issue on site where 12 JCC Toughbays (JC 040006) lights over 7 circuits all have the same issue.
Turn on - 100% on as expected
Power off SL - off/ charging as expected
Turn off at key/sw - off/ not charing as expected
If you turn rcbo back on and then flick the key sw to on the non emergencies come back on but all emergency fittings are only at 1% and the smd's are barely lit.
All are testing correctly for, zs, switching, etc.... as expected according to the sparks on site
First thoughts people? Off to survey tomorrow.
Can you sketch a wiring diagram of your setup?
Reply to JCC Toughbay - Emergency Issue in the Lighting Forum area at ElectriciansForums.net
DIY query Have narrowed down the source of an occasional trip to one light circuit which is a varilight v-pro master dimmer slave set up. This...
Hi all, I'm looking for a bit of assistance please from those that know more about this stuff than I do. Currently in a rented flat and there's...
Hi Guys Looking to see if anyone has had the same issues. I went to a tennanted property last year where the house lights were flickering and all...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Hope this all makes as much sense as i can make of it and my "problem" can get sorted via some guru on here... Just a quick background on myself...
