Discuss Klein Tools Holesaw Sets in the Electrical Tools and Products area at ElectriciansForums.net
RDB85
Trainee
Are any of these holesaw sets any good:
Sizes most used in rough order of priority.
note, this will change if you are in a specific type of electrical work.
20mm
25mm
32mm
16mm
40mm
50mm
plus specific sizes for downlighters may need to be added
Won't be much use to an electrician in the UK.
Are you wanting to start from scratch or do you have a few sizes to which you'd like to add?
I’m looking to start from scratch. I did look at Armeg but they are so expensive. I’ve a voucher to use so I can get them half price. They do an electrical set.
20mm
25mm
32mm
16mm
40mm
50mm
thanks, which brand of Holesaws and Wood drillbit do you recommend? I hear the Bosch are good, any experience with a brand that you were impressed with?
For steel, I use these
https://www.NoLinkingToThis/p/starr...rc=aw.ds#product_additional_details_container
for wood, I use these
https://www.NoLinkingToThis/p/bosch-expert-spade-bit-set-8-pieces/984ky
for stainless steel, I use these.
sweet thanks, for making holes in plastic boxes etc. do you use the same starret holesaws? I saw a video of an electrician recommending to drill it in reverse which prevent cracking of the plastic
Starrett holesaws are hard to beat in terms of quality and price. Yeah you can probably find better, but not at Starrett prices and many big names produce holesaws that are little more than junk when it comes to cutting steel.
Worth a mention are the tiny sheet steel holesaws produced by Armeg (Acceler8), CK & Starrett. Very neat cutting and a lip that stops intrusion into trunking or the likes. Oddly enough I wouldn't touch Starrett's version of these as I believe the pilot bit can't be replaced.
The holesaw set James linked above is a good starting point, with no useless sizes.
As above I always use Starrett and sometimes Bosch for hole saws
I also have some cheapo ones from screwfix which are fine for cutting DL holes in plaster board
Reply to Klein Tools Holesaw Sets in the Electrical Tools and Products area at ElectriciansForums.net
Register your Klein Tools online today to access tool details and protect yourself against tool theft! If you own Klein Tools in the USA or the...
https://www.amazon.co.uk/5-Piece-Insulated-Screwdrivers-Klein-32268INS/dp/B07BYWGB7P/ref=sr_1_1_sspa?crid=3PLITJ6TRAEVH&keywords=klein+vde+screwdri...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
I’ve been weighing up the idea of a Milwaukee Packout as a Storage Solution. I’ve had a fair amount of bags and they have been okay but then they...
5K
Good evening all. I have a couple of learners with hypermobility issues - which causes their hands to be sore after a day in the workshop. Has...
