Discuss LED lighting upgrade - PCR? in the Commercial Electrical Advice area at ElectriciansForums.net
Hi all,
We've been asked to upgrade 450+ 6ft single fluorescent battens to LED. The client had requested for each fitting to be connected into the existing wiring via a plug and socket arrangement to aid the maintenance team in the future. The existing wiring will be reused and is 1.5mm 3-core & earth. At present the existing battens are hard wired.
Wondering if anyone has come across any other options to act as a PCR mounted on a BESA box? Looking for something quick - push fit connections for the hard wiring would be preferable
Straight swapping that number of fluorescents to LED may have issues with inrush current of LED.
Not sure if its less or more than fluorescents kicking in.
Reply to LED lighting upgrade - PCR? in the Commercial Electrical Advice area at ElectriciansForums.net
R
I am looking into LED lighting for a Grade I listed church, parts of which are 800 years old. The lighting must be simply dimmable with a colour...
BMS installers have attended. After fitting the panel they also replaced the aged lighting in the boiler room with 6ft LED battens as instructed...
Hi Guys I've fitted a few emergency lighting circuits to both domestic and commercial installs before, I've come across one I can't get my head...
Hi, I am restoring an old art deco, wall mount medicine cabinet. The cabinet has an 18” fluorescent light tube on each side. Before I put a lot...
