Search the forum,
Discuss LED Strip Lights... in the UK Electrical Forum area at ElectriciansForums.net
Electreacle
Trainee
Hi, can anyone recommend the best but not so expensive LED Strip light kit and where is best to purchase from please. Installation environment is in a kitchen on the edge of a plinth (straight run), the next is to cover two cupboards that are separate from each other but has no pelmet. Would you recommend a diffuser tray to limit the glaring? Does the diffuser come with the kit? And also can this kit be cut to cover the two cupboards? (Is there any manufactured joints that come with the kit?)
Thank you in advance :)
Just too many to choose from, they all come with their own corner connectors etc etc. some dimmable. Limitless shades of Warm White/Cool White/Natural White. Never seen the aluminium profile/diffuser with strip as a 'kit' but you never know!
You'll probably end up with 10 different recommendations and still not know which one to go for.
Personally I like the Teucer range 24v but not the cheapest!
Would you recommend getting a low voltage range or go for mains powered?
I appreciate the response:)
Would you recommend getting a low voltage range or go for mains powered? I appreciate the response:)
You should find the led strip light with the milky silicone tube and also professional connectors
try Tagra Lighting , Manchester. They make bespoke kits to your specification.
Reply to LED Strip Lights... in the UK Electrical Forum area at ElectriciansForums.net
I have three Aurora Fluorescent linkable (linked) under cabinet 'strip' lights (c.21cm each) under the kitchen cabinets and over the sink area...
I am currently looking to add 12v led cob strip lights to my mother's kitchen but confused what I need. There are currently mains wires under the...
Hello, I'm new to this and I'm looking for someone to review my wiring diagram. I'm not sure if I need a fuse block because I'm using an XTM...
Hi Guys Never used LED strip lighting before. Customer wants the cornice strip lighting around bedroom so I can access loft space if required...
Hey all, I'm not sure if I'm over thinking this, but I can't seem to find the answer to what I believe should be a simple question. I picked up...
