Discuss LifePo4 addition to boat battery bank question in the DIY Electrical Advice area at ElectriciansForums.net
Hi, advice please if this would be fine and not cause issues with either the batteries or the inverter. I have read that LifePo4 batteries aren't compatible with older alternators. So is this workaround ok? - Leave existing leisure batteries as they are (2 x 100 AH) connected parallel, charged by alternator from engine. And then from here add a 12v smart charger supplying the 2 100 AH LifePo4 batteries for topping them up?
Thanks.
Reply to LifePo4 addition to boat battery bank question in the DIY Electrical Advice area at ElectriciansForums.net
I live in the Philippines where the power is bad, we have constant outages and when it does work the voltage ranges from 160-255v and the hz...
I have an 5kW inverter and 48V Lithium battery with inbuilt BMS. As you would be aware, when inverter gets battery power, immediately the...
Good morning all. Before I start I am not an electrician and am relatively new to this topic. Current set up Axpert 5.5 Kw inverter, 7 x 420...
I am a retired Electrician and started looking at Solar Power, (Black Magic to me), after much reading of "How To", I decided to build myself a...
