Discuss Lighting timers in the Australia area at ElectriciansForums.net
Hey there guys n Gals. Just needed some ideas, any of you got thoughts on best type of timers out there...got shop front , guy wants his outside caneope lights and inside display lights comin on with timer when shop closed. not sure of load yet, but there like 9 or 10 LV dwn lghts and a strip light i think he got himself to be boxed in his caneope all needing new circuit with this timer included....just thinking best way to do. and timers on market. 1st commercial number i had...He got 2 x wylex dual rcd boards with spares....he 1st floor board in basement...so ideally he wants to control where he is ....
anyway many many thanks
Hi There
We have used SANGAMO ROUND PATTERN time switches for shop lighting they are good, but they are expensive, around £123,other way we have done it is din rail mounting time switch and modular relay both dorman smith, watch cheap time sws some only rated for resistive loads and fluorescent fitting with chokes are inductive and can weld contacts together, have a chat with your local supplier they should have something.
Thanks the bassman, yeah gone for the din rail BUT yes as you say i gotta watch out for the resistive loads, thing is its both i believe, i got a proteus (yes cheap) as their boards are proteus...and as per the instructs. specs are awful.....it says glow lamp load 1000w i am taking that as resistive ...being glow lamp....mayb wrong guess need check.....its the single mod with timer dial...on side......
Reply to Lighting timers in the Australia area at ElectriciansForums.net
A friend of mine wired a 10mm 3 core armoured cable to his shed before I got involved and wired it himself already. He wants make it an air bnb...
Good afternoon guys, got a new light fitting, which is not supplied with the usual female terminals for wiring but rather has a short wire...
This is quite lengthy so get comfy... I had a bizarre call out relating to a job I attended about five years ago. The situation was they were...
Got called to "a flat in Manchester has no hot water" at 16:30 today and to be frank I was a little miffed to have to attend. So arrives at site...
7K
I commissioned an EICR to be done on a property that is in Wales as this is now a requirement in order to let on any new tenancies after 1st...
