Search the forum,
Discuss Lithium Ion Battery fires in domestic BESS in the Solar PV and Solar Panel Installers area at ElectriciansForums.net
Hello, I'm part of a team doing risk assessment analysis of Lithium Ion BESS. Des anyone know of any domestic (house, apartment, garage, etc) fires caused by Lithium Ion batteries in a household BESS system? Thanks
Not personally aware of any but was told by a fire safety officer in Bath (avon and Somerset fire and rescue) that they are discussing the risks and there was suggestions that BESS should be registered with the fire service so that they are aware that in a fire the batteries could be in the building. WHen going to propertieds with solar pv they will assume until proven otherwise BESS is present. He said he could foresee a scenario where the BESS must have an external firemans switch so that in grid failure or fire they can cut off the battery generation inside the property from outide before going in.
Same fire officer also said that if they were in the loft and caught fire the fire serevice would almost certainly refuse to enter the building (unless resuing people) to try and put them out due to the weight and crashing through floor but also accessing them to put out a lithium ion fire is goign to be difficult. woudl likely lead to your house buring down and they would look to only prevent the spread to neighbourign properties.
the register of battery installs would allow them to know of any risk if going in a house and the fire spreading to them and quickly getting out of control .... seems sensible idea.
Your best point of contact would be individual fire services - maybe the press or fire safety teams.
Thanks very much Gavin, this is helpful!
Reply to Lithium Ion Battery fires in domestic BESS in the Solar PV and Solar Panel Installers area at ElectriciansForums.net
Hi, I'm completely rewiring a 9 bed 3 storey HMO in Jan, The fire detection required is just some linked lithium detectors in the...
M
The idea of having electrical power from 240volt AC sockets in a sectional building not on the national grid is becoming popular among those who...
I've asked a similar question before I think and we came to the conclusion that apart from new houses and HMO's etc there aren't any rules about...
Hi all, a very long time I did a swanky grand designs type new build in the middle of nowhere, so in the middle of nowhere that it's a house with...
Hi, I’m an industrial electrical engineer apprentice working at a wastewater treatment plant, I’ve been really enjoying the job which I’ve been...
