Currently reading:
Long distance subpanel
Discuss Long distance subpanel in the UK Electrical Forum area at ElectriciansForums.net
mrshanes
Hello. I need a little DIY help. I'm building a stage (i.e. freestanding deck) in my backyard. I want to put a 50 amp outdoor subpanel at the stage with 4 20 amps circuits in it. We plan to host bands and this allows them to power their setup without a generator. The issue is it's located about 180 feet from the subpanel in the house I want to draw from. Can I run 6/3 copper that distance from a 50 amp circuit? Is the voltage drop too much? What options do I have here? One restriction I have is that the conduit form the panel inside to get outside the house is 1". (located in the US)
I believe that you can run that far with the wire size and breaker size. The 1 inch pipe will be the problem. You will need to buy single wire instead of cable. By code you can put 3 # 6 THHN wires and a # 10 ground but you better have some help and plenty of wire pulling grease. I’m sure the band equipment won’t pull that much amperage
Reply to Long distance subpanel in the UK Electrical Forum area at ElectriciansForums.net
