Search the forum,
Discuss Lost Neutral on 3 Phase system - how do you calculate the effect on line voltage in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I know the effect of a lost neutral (floating neutral) on a 3 phase system, and the theory of why the line voltages can vary.
However, I have been attempting to show this by calculating the line voltages of a phase system at given loads on each phase.
Lets say:- Red 296 Amps, Yellow 279 Amps and Blue 219 Amps.
How do I take these loads and the known 3phase voltage @ 400V and calculate the individual line voltages in a lost neutral situation?
I hope i'm making sense.
To show the varying line voltages you can plot it as a phasor diagram then use Millmans Theorum to calc the voltages wrt supply neutral. There's other mathematical methods but they can get messy unless you're a bit of a math whizz.
I'll see if I can find a link to an explanation that doesn't go too deep into technicalities.
**edit here's a quick explainer
Reply to Lost Neutral on 3 Phase system - how do you calculate the effect on line voltage in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
When I joined this forum a decade or so back, there was a discussion going on about a welder that was connected with a 3-core cable to L1, L2 and...
Hello, this is my first post here. I have a little experience with most types of household wiring through a decade of DIY remodeling, and...
I have a 230 Volt single-phase circuit with a 100 Amp cutout fuse and a 100 Amp MCB switch, so the supply is rated at 23 kVA. Only about 13% of...
6K
I understand how to calculate the current in the neutral conductor on an unbalanced three phase installation, however am struggling to grasp how...
6K
Hello everyone my name is Tarek, i work as a concert and show lighting operator with over 20 years of experience in this field, so i have gained...
