Discuss Low Voltage Dimmer Help in the DIY Electrical Advice area at ElectriciansForums.net
I recently purchased these pathway lights:
After installing them I realized they're too bright, so I installed one of these dimmers:
The dimmer doesn't dim the lights very much. They go from extremely bright to very bright. They are on a 14v terminal off my Vista MT-600 transformer. Any idea why the dimmer wouldn't be working properly? Is there another dimmer you recommend I try?
Thanks,
Frank
The pathway lights are designed for a range of input voltage (12 - 24) so probably have some sort of internal driver or regulator to control current to the LED's. So the internal electronics will probably fight pulse width modulation from the dimmer you have.
You could try reducing the supply voltage to all the lamps below the specified minimum, but that may introduce other effects, like flashing, and/or the lamps may run at different brightness to each other. Worth a try though!
The spec for your lights doesn't mention whether they are dimmable or not, but it seems they may not be ☹️
As Avo Mk8 mentions, these lights will have an internal driver / regulator, which will try to produce the specified light output. So NO dimmer is likely to work properly.
Reactions: DPG
I'm going to return them and order these instead:
Gardenreet Brass Well Lights Landscape In Ground,12V LED Low Voltage Landscape Lighting Well Lights for Garden, Pathway Without MR16 Bulb(One-Direction Turret) 4 Pack https://a.co/d/3uSb0JB
I should be able to replace the bulbs with what I want.
Reply to Low Voltage Dimmer Help in the DIY Electrical Advice area at ElectriciansForums.net
I have purchased spotlights as below, but they are flickering when I dimmed them down to around 15-20%. We have installed 8 x ALUSSO LED Recessed...
Hello. I’ve been racking my brain all day with this. Here is my situation and question: I have some OEM ambient lights in my vehicle. They are...
Evening guys! I have three of these bulbs on a ceiling light, controlled by a dimmer switch installed by an electrician...
Hi, I currently have 4 JCC LED down lights in my bathroom with a 2 gang dimmer on the outside. The first dimmer switch controls the LEDs and...
Hello, I live in Mexico, where I have a small, un-official trailer park on my property. The property is serviced by my privately owned, 650amp...
