Search the forum,
Discuss Marking holes for steel trunking in the UK Electrical Forum area at ElectriciansForums.net
Hi, silly question but in College we only learned how to mark up holes for end caps. I’m just wondering what the standard practice is for marking holes in steel trunking for attaching couplers?
The previous Electrician I was working with we used templates but there’s non on this site so i’m using a tape and set square but it seems fairly time consuming?
stupid question yeah
again I realise this is a amateur question
The fixings for end caps should be the same dimensions as those for couplers. (If the same make)
So mark up using an end cap and the coupler should fit.
Nothing to input to the thread but you might want to consider joining the trainee section if you're studying. PM @Dan for access
Block of flats in Perth around New Year, riser fire took out the top 3 floors. Open Concrete walkways.
Fixing 100mm galvo trunking (which was hand balled up from the ground) to the ceiling of the walkways, never again will I touch unistrut, zebs or trunking again in my life. My arms still hurt when I think about it!
Reply to Marking holes for steel trunking in the UK Electrical Forum area at ElectriciansForums.net
A bit of a mini essay but these questions have been building up in my mind over the last weeks and months as I've been studying and volunteering...
Last week I did a job for forum member joramtor. Link to the original post here...
13K
E
I think I've Posted this before, but I've just updated it. Some of the sparks where I work still get a little confused of what the different areas...
78K
Let me start this thread by stating that I am NOT an electrician in that it is not my "day job". I do however have and always have had an interest...
6K
mo the test
M
