Search the forum,
Discuss MCS registered electrician needed. in the Solar PV and Solar Panel Installers area at ElectriciansForums.net
Hello everybody!
I have just bought a new house in Kignsley, Stoke-on-trent and as the rear aspect of the roof is facing south almost perfectly- I would like to install a PV system.
I am qualified electrician and I have done around 150 installs myself working for big PV companies so I would take care of all wiring and my roofer friend would install panels on the roof. It would be 2.7pkw array with a single track SolaX inverter.
The only ingredient missing in all is that the install would need to be MCS registered and as it was always provided by the companies I was working for- I am not MCS registered myself. Do you lads know if I could have a MCS registered electrician to sign my install off? Provided all the testing results or maybe he would want to test it all by himself? If yes- how much would it cost?
Thanks!
Hi,i cannot believe,you have not had a single reply,since Jan 4th :rolleyes:
It would seem the PV job is struggling,or the enthusiasm has vanished.
You might be better off considering your own fitment of solar thermal,and at least get a smug,warm feeling while you wash.....which you not get from PV ;)
Hello everybody!
Thanks!
Hi did you find anyone by any chance, I’m in Staffs and have a similar situation. Thanks
Reply to MCS registered electrician needed. in the Solar PV and Solar Panel Installers area at ElectriciansForums.net
Hi. I'm not MCS registered but am looking into it from a Project Management perspective as opposed to an MCS installer. In a nutshell I'm trying...
I have been working as an electrician under an NICEIC Approved Contractor for the past 10 years. I have my C&G2365 level 1/2/3 (acquired before...
Hi wondering if you could help with some advice Been running an Essex/suffolk based electrical firm for last 20 years, mainly light commercial...
Hi I’m in the process of registering for mcs. I’ve done pv and battery course and done a fair amount of solar and battery installs. As part of...
My best mate has been medically retired from the prison service at the young age of 52 and has time on his hands :D He's looking at a 'plug in'...
