Search the forum,
Discuss medical locations query in the Commercial Electrical Advice area at ElectriciansForums.net
excuse the paraphrasing .I'm trying to figure out if lighting circuits in group 1 /2 locations HAVE to be on rcd.or if it depends on...eg...unprotected cables in a metal stud wall ...or if it is in a room containing shower
710.411.3.2.5 says ..in medical locations of group 1 & group 2...WHERE rcds are required only type A or B (not type AC) shall be selected..
then
710.411.4..TN systems says ..In final circuits (which presumably would include lighting ?)of group 1 rated up to 63 amp rcds SHALL be used
then
next paragraph says in medical locations of group 2 rcds shall ONLY be used for operating tables X rays etc.
it just sounds a bit conflicting to me...or maybe just too late at night to think clearly.
Hi - I'm not expert on medical locations, but this is my take :
710.411.3.2.1 : confirm if you are in room designated in gp 1 or 2 (where tripping itself causes a hazard as it interrupts a medical procedure). If so, then AC type RCD shall not be used. But type A or B (best in my view) may be used.
710.411.3.3 : confirm if your room uses IT system, if so additional protection by an RCD shall not be used.
710.411.4 : if TN used, use RCD spec from 415.1.1 (but type A or B) . Note the list of circuits is not exhaustive but it specifies some that are compulsory.
710.411.5 : if TT used, refer to 710.411.4
So I think for a non IT medical location 1 or 2 we should provide additional protection using RCD type B for lighting if required due to the usual cables in walls etc. Also lights are likely required to be emergency type.
I'm sure some more experienced heads will help out :)
Reply to medical locations query in the Commercial Electrical Advice area at ElectriciansForums.net
I am looking at installation of an architectural dimmer, that is will supply 6 channels, with 20A circuits each (2400W ea). Our hall has can light...
Hi all, I am looking for some advice regarding old rewireable (3036) fuse boards in regards to additions and alterations. I am an electrician and...
4K
I've started to move over to AMD 2 forms for my CU installs, if only because the schedule is so much easier to tick and I can stop sticking labels...
Hi all, Got an antique light fitting that for some reason she wants putting up (can't say I love it haha) however it didn't come with any...
Hi Everyone Thank you for accepting me into this group. I'm obvoiusly new to this forum so please excuse any mistakes untill I familiarise myself...
