Search the forum,
Discuss Megger MIT420/2 unstable continuity readings? in the Electrical Tools and Products area at ElectriciansForums.net
Chaps - having problems with a new Megger MIT420/2 insulation/continuity tester 'oscillating' and failing to give stable resistance readings in continuity mode with some motors (although it did it once on a Cal Card!). I don't think it's a duff unit, but anyone else have one and experienced similar? I've got various Flukes to hand which all measure the coil resistance of these motors swiftly and consistently. Following recent experiences with the AVO835 DMM, I'm just gaining the impression that under certain conditions, the autoranging goes haywire (autoranging doesn't seem to be Megger's forte, it's horribly slow on the multimeter). Normally, when it stabilises, the instrument displays the current at which it's measuring the resistance - when it has these mysterious failures, it just displays zero, like it could be hunting for the appropriate current.
Any thoughts?
Have you tried different test leads?
Yeah it's not the leads. It just looks like the autoranging goes haywire under certain conditions, probably with the test current rattling between a couple of settings. I haven't done a PhD on the manual but it doesn't look like you can set the range manually...
I think I'm right in saying the previous versions of these testers were manual range in continuity mode.
Reply to Megger MIT420/2 unstable continuity readings? in the Electrical Tools and Products area at ElectriciansForums.net
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
Over the last few days, I have stumbled across a number of threads that seem to point to a prevalent misunderstanding. Either that, or I have been...
Hi, This is my first post, although I have been browsing the forums for a little while now. I work in BMS and have my AM2 on friday. The nature...
T
Megger BM401/2 Product Code: BM401/2 Test button located on probe allowing the instrument to be perated manually. Accurate and fast true...
4K
T
