Search the forum,
Discuss Mis-use of tools in the Electrical Tools and Products area at ElectriciansForums.net
My daughter went one better, she wrapped all the flexes in tissue paper, then used scissors to trim it and 'missed'. This caused a spark that set the tissue paper alight.
When I entered the room every flex was still live AND impressively on fire!
This is the same daughter that tried to cool down a bedroom light by pouring water on it. Later the same day she wanted an explanation of how the dishwasher didn't explode like the light bulb did, as the dishwasher has both water and electricity.
She's turned out very practically minded
A very valid question. I always appreciate when people take an interest in how things work.
If you forget your cable rods and need to retrieve a cable without access to the other side of the fence....
A good old garden hoe to the rescue.
Reply to Mis-use of tools in the Electrical Tools and Products area at ElectriciansForums.net
I plugged a drill press directly into a GFCI outlet in the garage. Something blew up by the drill press switch. Since then the GFCI outlet LED...
I have pulled out an old evaporative system I purchased many years ago from storage to have a look at it and see if I can get it running. Was...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
Hi I'm looking for some advice for adding a time delay on my parent's shower room fan. My parents had a section of their garage converted into a...
