Search the forum,
Discuss Mounting EV charger on external meter cabinet in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Customer wants me to mount his EV charger on the back of an external, plastic meter cabinet. The cabinet is a new plastic one at the other side of his drive from the house with a separate consumer unit inside. This would be an ideal location for ease of installation.
Is this allowed or will I have to mount the charger on a separate post?
Can't find the regulation on this one. I have a sneaking suspicion it might be frowned upon by the DNO??
Any internal view? What’s all inside?
Looks fairly easy to knock over. A steel bollard at each corner to protect?
Meter cabinets might have a sticker inside telling you not to use it for anything else.
The problem here is, if you drill the back to feed an EVCP, and water gets in, the DNO will blame you if their equipment gets damp and they need to attend.
Reply to Mounting EV charger on external meter cabinet in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a client who wants an EV charger installed, charger TBC, but about 7KW, installed about 20m away from this installation. I've not done one...
4K
I would like to hide the cable to an EV charger. The consumer unit, meter cabinet and charger would all be on the same wall. About 5 metres from...
Hi. Not sure if it's the right place to ask, so won't be upset if it gets removed. Apologies if the terminology (PEN/PME/etc) is used...
7K
I am looking for advice on getting an upgraded 25 meter extension cable from my office into my car park to charge my EV from an IP66 rated socket...
I am looking to install an EV home charger for one vehicle, but possibly two in the future. I have a second unused (but still active) mains supply...
