Currently reading:
MR16 LED Help please!
Discuss MR16 LED Help please! in the UK Electrical Forum area at ElectriciansForums.net
Good evening,
We are renovating our house and I replaced the halogen MR16 bulbs with Philips LED dimmable version in one of the bedrooms. Once fitted they appeared to work fine. I left them on and came back to the room to find it in darkness and now noting works. (Even tried replacing the old halogen bulbs) The lighting on on a 1 gang 2 way dimmer set up with 2 dimmers operating the lights.
Hopefully someone can help!
Many Thanks
Martin
So, unless you upgraded the transformers for the lights to dimmable LED compatible ones and are using a dimmer capable of driving such things, you could have damaged the transformers or the dimmers.
Hi Martin - you have just witnessed the unfortunate lack of interworking with lights. If you felt able, you could perhaps replace the dimmer with a switch and see if that works. Take pics of the connections before starting and before that make sure the power is off ....
If you've not got any test gear, it might be worth employing the services of a local (preferably recommended by family/friends/colleague) spark to check the various components to establish exactly what's wrong.
Reply to MR16 LED Help please! in the UK Electrical Forum area at ElectriciansForums.net
