Discuss Must have electricians toys in the Electricians' Talk area at ElectriciansForums.net
To be honest, if you stitch drill just around the outside, you'll only have 5-10mm gap around the box, can be done just as neatly that way as it can with a box cutter thing.
Give me the poshest of houses,a drill and chisel
I will cut a box into the wall as quickly as anyone with a box cutter ( a real childs toy in my opinion) and the disturbance wouldn't be noticed
Leave your box cutters on the building site,they don't belong where accuracy and top class workmanship is required to produce unseen box sinking results
They are ok for butchering walls where the damage inflicted can be covered over and hidden. and where the air pollution covering the walls and furniture is not an issue
I forgot this little charmer,the younger ones amongst us may not appreciate the charm
The first time I got myself a Yankee screwdriver,it was definitely toy time
It was the short version about a foot long,I was hooked,I went and got the medium and large versions with borrowed money
I would spend ages cleaning those shafts
I had the fastest eye removing tool in the village
Yep too true, bought a box cutter and used it once, they are terrible, only any good in breeze and the mess is too much
i actually use a stanley knife to score around the outline of the box, it prevents to plaster chipping and/or cuts the wall paper, then as said chain drill the inside with a drill bit about 14mm with a bit of tape to indicate depth, and knock it out with a small comb chisel
you wouldnt know ive been there
Im stating to think i need an inspection camera my biggest client insists on using mr11 downlights, usually 52mm cut out no ones getting arm or hand in that hole
It was the short version about a foot long,I was hooked,I went and got the medium and large versions.
I can't believe, I had forgotten about the Yankee, you absolutely were not a "real" electrician without one. Must have a look, I think I still have the "medium one" in the attic.
Reply to Must have electricians toys in the Electricians' Talk area at ElectriciansForums.net
Hi, Just wondered if anyone knows whether there is such a thing as a distance learning version of the level 3 (C&G or EAL) Electrical...
4K
Hi all, Disclaimer: I'm not an electrician and have very basic knowledge of electrical installation. We've been putting in a new kitchen into an...
Hi, I've recently had my broken oven replaced in my flat and I paid for delivery and installation. It was hardwired through an unswitched plate...
