Search the forum,
Discuss Na Electrical - Electricians In Lancashire in the Directory of Electricians in the UK area at ElectriciansForums.net
We are an electrical company aiming to provide affordable, reliable and competitive service to clients in and around the Preston and wider area.
All work is carried out to the highest standard and complies with the current regulations. All our products comply with recognised British standards and have a 1 year guarantee.
We are experienced in all types of domestic and commercial electrical systems.
As an Electrical company we offer a full range of electrical services, from small jobs to full rewires.
We provide Electrical Insstallation Condition Report (formally known as Periodic Inspections) and Testing to BS7671 and PAT testing.
We work for numerous builders of different sizes, completing a range of small extensions to large house conversions and new build.
We pride ourselves on providing a fast and reliable service, and would be pleased to provide a quote for any forthcoming electrical projects you may have.
Our Website is currently under construction, so please check back again soon.
We are happy to provide quotes for any form of domestic or commercial work.
All quotations will be valid for 30 days from the date of issue and are subject to a copy of our standard terms and conditions, a copy of which is available on request.
One of the most frequently asked questions is how much will it cost to re-wire my house ?
This is a difficult question to answer as each property is different, but to give people some idea a 3 bedroom house with an electric shower, electric cooker ( single hob or oven ) 10 lights and 25 sockets including a 10way dual rcd consumer unit, bathroom fan and 2 smoke alarms, will be around the £3500 including vat price range.
This will give people some idea of what to budget, but please contact us for a more individual no obligation quotation.
EICR reports ( formally known as PIR reports )
Although for privately owned domestic properties it is not a statutory requirement to have an EICR performed on the electrical installation, it is advisable that the electrical installation of all properties are tested and inspected at regular intervals and no longer than once every ten years.
For privately rented properties it might not be a statutory requirement, although that is dependent on the area that you live in. It is important to ensure that all electrical appliances and fittings within the property are safe and in good working order, as you can still be held liable if there is an injury caused by an unsafe electrical installation.
For a House of Multiple Occupancy or an HMO, it has been a statutory requirement for over five years; it states that the building management should;
‘ensures that every fixed electrical installation is inspected and tested at intervals not exceeding five years by a person qualified to undertake such inspection and testing’
It is a statutory requirement that commercial properties and properties where the public have access; are regularly checked and that an EICR is perform on the electrical services. The period between inspections is determined by the function and the use of the building.
Intruder Alarms
While an intruder alarm can act as a deterant there is no garentee that your property will not be targeted by a burglar. It is considered more likely to happen if there are no visable signs of an intruder alarm.
There are several different types of alarms now widely available with wireless technology being used to aid installation by allowing for very little disturbance of internal decor. This does not mean that wireless alarms are suitable for all properties and we recommend a site visit to discuss options available.
Consumer Unit Replacement
If your mains unit is still of the type with fuse wire in each individual fuse, then maybe it is now the time to have your unit changed. A more modern unit, means no more fumbling around with fuse wire each time a problem occurs. Modern units provide switching off of the power extremly quickly in the event of a fault.
Did you know that an old fashioned fuse wire fuse can take upto double the rating of current to pass through it before it will fail !
Outdoor Power / Lighting
Modern led lighting provide higher output for less cost to run. There has never been a better time to install security or decorative lighting to enhance your property. There is also the convenience of having an outdoor power socket installed, either for mowing the lawn, or to remove the need for extension leads when putting on your Christmas light display.
Reply to Na Electrical - Electricians In Lancashire in the Directory of Electricians in the UK area at ElectriciansForums.net
Hi, Hoping someone can clarify for me. I've recently moved into a rental property, the landlord had new electric radiators installed and a new...
Electrical2Go - Megger MFT Deals! Upgrade your toolkit with our exclusive offer! Purchase any of the Megger advanced multifunction testers –...
Electrical2Go - Home Security: Using Floodlights, CCTV, and Door Entry Systems In an era where technology is advancing rapidly, home security has...
Electrical2Go - Green2go Launches for All Your Solar, EV Charging and Renewable Needs Green2Go - for All Your Solar, EV Charging and Renewable...
Antac are looking for an Electrician to join the team, specialising in commercial installations across Hampshire. The role involves small...
