Search the forum,
Discuss New meter installation and registration in the UK Electrical Forum area at ElectriciansForums.net
Hello to all
I have a customer asking to have an extra separate meter from service head the services head has a 1361 type 1 with 100amp fuse so good supply, this is my first meter job I am an AC electrician but hasn’t done meter registration or connection any help would be appreciated, Regads
Aswad
Hello to all
Aswad
If it's a completely new supply and meter they want, then it will be the DNO who have to do the work. Their website will likely have the appropriate application forms - This is for UK Power Networks who cover my area (but it may not be cheap). The DNO will provide the new service head, and their energy supplier will then supply the meter.
If it's just that they want a check meter to cover a sub part of their supply, like a granny flat, then you can buy meters to install yourself with it's own tail feed for the circuit(s) involved.
many thanks Darlec
No way I only need to look at the service head and not pulling or testing anything,
Basically the supply is good and all they want is after main fuse the tail to be in two one old meter and one they want me to install and register a new meter connecting to the existing supply as it will be only for hallway lights as landlord meter which is shared at the moment, so to supply and install and register a new meter to existing supply,
I think all I need it’s a block and tails and new meter?
than I will connect it to a twthree way RCD protected DB?
I just don’t know how to apply for new meter or what to do first?
Regads
many thanks Dartlec
No I only need to look at the service head It’s a TNS with 100 singleMain fuse entry supply coming to a new smart meter,
Basically the supply is good and all they want is after main fuse the tail to be in two one old meter and one they want me to install and register a new meter connecting to the existing service head supply as it will be only for hallway lights for landlord meter which is shared at the moment, so to supply and install and register a new meter to existing Service supply,
I think all I need it’s a Henley block and tails and new meter?
than I will connect it to a two or three way RCD protected DB?
Regads
If your customer wants it completely seperate from the existing meter then the DNO will have to supply a new set of tails and meter so that they know what is happening and everything stays metered and charged accordingly.
If the tenant just wants to see how much they are using for the communal areas then you want to be looking at henly blocking the tails after the existing meter and then splitting the tails to a check meter (which you can readily get) and the existing consumer unit.
If you need to speak to the DNO I think 105 is the number to call, it should direct you to whoever that is for the area you call in. (Not 100% as I haven't checked myself)
Reply to New meter installation and registration in the UK Electrical Forum area at ElectriciansForums.net
We had a new supply installed this week. DNO installed new cut out and fuse externally. Meter operator sent his engineer to move the meter in the...
Hi, while carrying out an EICR at a farm cottage on Friday i came up against a problem early on. Whilst measuring the Ze the reading i obtained...
Hi All, I have a client who is developing a plot of land for a single house. Currently, their 100 amp service cut-out is in a cubicle fed by...
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
Hi all -- full disclosure I am a 'DIY-er' but wanted to post here for greater visibility seeing as I certainly won't be doing this work myself...
4K
